Assassin X 120 Refined SE: a 148mm cooler from Thermalright!
Thermalright is definitely releasing fans faster than its shadow. Here is a new reference with the Assassin X 120 Refined SE. It is a 120mm heatsink measuring only 148mm high in total. A model that should go everywhere!
Assassin X 120 Refined SE : 148 mm high for this model in 120 mm !
Thermalright Assassin X 120 Refined SE With this new model, Thermalright offers us a compact reference measuring only 148 mm in height. Otherwise, the radiator remains relatively thin with its 46 mm thickness for 120 width.
The cooling tower displays a total of 51 aluminum fins with a first one in black color. On this last one we can recognize the logo of the brand stamped in the material. Finally, we can count on a total of four nickel-plated copper heat pipes. However, we do not know if they are in direct contact with the CPU or not.
Regarding the ventilation, we find a TL-C12C fan in 120 mm powered by PWM. The latter runs at 1550 RPM at full speed and generates an airflow of 66.17 CFM for a static pressure of 1.53 mmH2O.
Clearly, this is not a high-end heatsink, just the compatibility of the sockets attests to this. In fact, the brand intends it for Intel LGA-1000 and AM4 sockets. No LGA-2000 here.
All that remains is to find out the price.
Here is the technical sheet of Thermalright !
