And here we are again with Thermalright who announces a new ventirad. The new model in question is the Assassin King 120 Mini White, an ultra compact 120mm model. Indeed, despite its 12 cm size, it is only 135 mm high !
Assassin King 120 Mini White: only 135 mm for this 120 mm tower fan!
With this new product, Thermalright announces a heatsink with a really compact tower format. Indeed, despite the presence of a 120mm fan, this model is only 135mm high. Roughly speaking, it is 10 mm less than the H7 Quad Lumi from Cryorig !
Next to that, we have a radiator made of aluminum fins. There are 46 of them and a total of five 6mm copper heatpipes run through them. White” model, we will find a white coating on the entire product: heat pipes, fin and fan.
Moreover, the ventilation, let’s talk about it because a TL-D12W-S mill will take care of the cooling. We are talking about a 120mm fan powered by PWM and operating at up to 1500 RPM. At full speed, it will generate an airflow of 64.87 CFM and a static pressure of 1.53 mmH2O. Of course, we will not miss its beveled corners or its RGB lighting placed on its central hub.
The question of the compatibility of the sockets is quickly answered. It is a product that can be installed on Intel’s AM4, LGA-1000 and LGA-2000 sockets.
Finally, it is impossible to talk about the price since the brand simply did not mention it. On the other hand, we can’t deny that it is an interesting solution considering its compactness!
Here is the technical sheet of Thermalright !
