Arctic P12 Max: Arctic fans in white!
Arctic has come up with a new color for its P12 Max fan. The famous Swiss fan is now available in full white.
P12 Max: a white version of Arctic’s famous fan!
Arctic P12 MaxThese fans feature a 120 mm PWM-powered model. It operates from 200 rpm to 3300 rpm… And will adopt a semi-passive operation under 5% PWM signal. Moreover, the rest of the specifications highlight a mill generating an airflow of 81.04 CFM (137.69 m3/h) and a static pressure of 4.35 mmH2O.
Physically speaking, the fan still boasts five wide, strongly curved blades. These are also joined together by an internal hoop, while the frame features rubberized silentblocks to attenuate vibrations.
This white color is applied to the entire fan: blades and frame, although the silentblocks are light gray.
In terms of price, Arctic advertises its mill at €14.99, €1 more than the black version. Unfortunately, this white model will not be sold in the more economical 5-pack… At least, not for the moment.
Here’s Arctic’s product sheet!
