ARCTIC launches its P12 Pro Reverse A-RGB
ARCTIC has just added a new series of fans to its catalog, with the P12 Pro Reverse A-RGB. The principle behind “Reverse” fans is to draw in air from the rear, so you can take advantage of the design of your fans inside your case. Indeed, when designing a cooling system within your case, it’s often the back, much less aesthetically pleasing, that is visible. The addressable A-RGB backlighting features twelve controllable LEDs. In terms of specifications, it has a speed range from 500 to 3000 RPM, a flow rate of 73 CFM and a static pressure of 4.50 mm H2O.
The MSRP for this P12 Pro Reverse A-RGB is 20.49 euros, with the 3-pack priced at 44.49 euros. But the good news is that there’s now a discount on the P12 Pro Reverse A-RGB for 12.49 euros and 28.99 euros for the 3-pack.
Other models in the P Pro Reverse series will follow in the coming weeks:
– P12 Pro Reverse
– P12 Pro Reverse – Pack of 3
– P12 Pro Reverse A-RGB (white)
– P12 Pro Reverse A-RGB (white) – Pack of 3
– P14 Pro Reverse
– P14 Pro Reverse – Pack of 3
– P14 Pro Reverse A-RGB
– P14 Pro Reverse A-RGB – Pack of 3
– P14 Pro Reverse A-RGB (white)
– P14 Pro Reverse A-RGB (white) – Pack of 3
