Aorus AR Series: 120 and 140 mm fans from Gigabyte!
If Gigabyte has already diversified in many areas of the hardware world, fans were missing from the brand’s catalog. Now, these are included since the manufacturer offers its Aorus AR Series. We’re talking about 120mm and 140mm fans!
Aorus AR Series: a mill in 120 mm and another in 140 mm!
Aorus AR Series
The 120mm is on the left, the 140mm on the right
With its two fans, Gigabyte offers us mills in 120 mm and 140 mm. The latter also benefit from a PWM power supply and these two models will be able to operate from 800 RPM to 1700 RPM. At full speed, the brand puts forward:
  • Airflow : 40,85 CFM for the 120 mm against 60,64 CFM for the 140 mm
  • Static pressure: 1,48 mmH2O for the 120 mm against 2,18 mmH2O for the 140 mm
Besides that, both fans offer a luminous lighting diffused via six diodes placed at the central hub. Otherwise, the frame offers rubber pads to reduce parasitic vibrations as much as possible.
Gigabyte Aorus AR Series Unfortunately, Gigabyte has remained silent on the price of its fans since it has not been communicated. However, we know that the brand guarantees its mills for 3 years. All that remains is to see how it blows on a radiator or in a case.
Here and there are the Gigabyte datasheets!
