AOC unveils its Agon Pro AG276QZD with 240 Hz OLED panel
The AOC brand unveils a new display that promises to be particularly high-end, the Agon Pro AG276QZD. In fact, the brand is offering us a 27″ reference equipped with an OLED panel that promises to be particularly responsive. We’re talking 240 Hz!
Agon Pro AG276QZD: a 240 Hz OLED display!
AOC Agon Pro AG276QZDThis screen is equipped with a 27″ OLED panel. The latter promises to be highly responsive, thanks in part to its high refresh rate: 240 Hz. It also boasts a very low latency of 0.03 ms gray to gray. This also includes G-Sync support.
In terms of display, we find a QHD resolution (2560×1440) with 10-bit color depth. This gives 100% coverage of the sRGB color gamut and 98.5% for DCI-P3. Finally, brightness is 150 cd/m², with peaks at 1000 cd/m². Contrast is at 1500000:1, while HDR10 certification is available.
Of course, there’s a stand that allows adjustment in all directions. The stand is equipped with a handle for easy movement. Likewise, a quick-release mechanism makes installation quick and easy. Of course, a USB 3.2 hub is also included.
The price is top-of-the-range: £879.99, or over €1000 after conversion.
