Antec presents its NeoECO Gold M ATX 3.0 power supplies!
American brand Antec unveils new power supplies. The program includes a total of three models with power ratings ranging from 850W to 1300W. What’s more, some versions come in white!
NeoECO Gold M ATX 3.0: three power supplies from 850W to 1300W!
Antec NeoECO Gold M ATX 3.0
With these power supplies, the brand offers three ATX-format power supplies. However, despite power ratings of up to 1300W, depth remains limited to 140 mm. Otherwise, the models are available in 850W, 1000W and 1300W, with the 1000W version also available in white.
The electrics are 80 Gold certified. The design is based on an LLC-type circuit with DC-DC converter and active PFC. Of course, Japanese capacitors are also used, as is the unique 12V rail. The following electrical protections are provided: OCP, OVP, UVP, SCP, OPP, OTP, SIP and NLO. Finally, ventilation is semi-passive, and these models are ATX 3.0 compliant.
Cable management is entirely modular, with a 24-pin ATX cable and two EPS12V CPU 4 4 pins. For graphics, a 12VHPWR cable and four PCIe 6 2-pin connectors are supplied. Finally, there are twelve SATA connectors followed by four molex… At least for the 1300W version. Expect reduced connectivity on the 1000W and 850W models.
Prices range from €180 to €230, depending on power. As is often the case, the more watts, the more expensive. Oh, and the manufacturer’s warranty is ten years!
Here are the Antec product sheets!
