An Alphacool waterblock for RX 7900 XTX Red Devil !
German brand Alphacool has come up with a new waterblock model. This time, it’s PowerColor’s RX 7900 XTX Red Devil. A model from its Core series!
Alphacoool unveils a waterblock for AMD’s RX 7900 XTX Red Devil!
Alphacool Core RX 7900 XTX Red DevilAs we can see, this is the brand’s new waterblock series. This is evident not only in the liquid passages, but also on the terminal itself. The latter is minimalist and rounded.
This is a full-cover model that cools all the card’s critical components. Heat from the GPU, memory and power supply stages will be actively dissipated.
The construction features a nickel-plated copper base with an acrylic top. This part will also benefit from aRGB lighting!
As for compatibility, this is a model that will fit both the basic Red Devil models and the Limited Edition declination without batting an eyelid! Dimensions: 287.21 (W) x 123.10 (D) x 5 (H) mm.
Unfortunately, prices are still high, as you’ll need to spend around €200 on the brand’s online store.
Here’s the Alphacool product sheet!
