AMP 1000 White : a 1 kW white power supply from Phanteks !
New power supply at Phanteks which announces the arrival of a 1000W block of white color. This one is also very compact with only 14 cm of depth. In short, this AMP 1000 White seems to offer an excellent ratio power/size.
AMP 1000 White: a very good space/power ratio!
Phanteks AMP 1000 WhiteWith this new power supply, Phanteks offers us a white power supply. On the shell, we will find some markings like the reference on the sides. Otherwise, we notice that the fan benefits from a thin grid. Moreover, speaking of the fan, you should know that it has a hybrid mode of operation and measures 120 mm on each side.
Otherwise, as we can see, we find a fully modular cable management. The latter offer six PCIe 6+3 pins, twelve SATA, five Molex and two EPS12V 4+4 pins. Of course, the 24-pin ATX is still part of the system.
On the electrical side, the 80+ Gold certification should be mentioned first. Otherwise, internally, we have the right to a single 12V rail of 83A. On the protection side, we have what we need with the OPP, OVP, SCP, OCP, OTP and the no-load and reset protections.
For the price, you will have to pay 159,90 € which is not so excessive considering the power.
This way to the Phanteks datasheet!
