Alucia SC: Akasa fans in 120 mm and 140 mm!
New fans are in sight at Akasa which announces its Alucia SC series. New fans, without RGB lighting that come in 120 mm and 140 mm. In addition, the price is attractive!
Alucia SC series : fans in 120 mm and 140 mm !
Akasa Alucia SCEven if the new Akasa fans are without RGB lighting, this does not prevent the brand from putting a little color. Indeed, we will find shades of blue on the blades and the silentblocks on the frame. However, it is a navy blue rather discreet.
Otherwise, the brand declines its fans in 120 mm and 140 mm. On the other hand, whatever the format, we find the same number of blades: nine. Moreover, they remain quite thin and rather elongated while being strongly curved.
In short, what interests us here are the characteristics. In any case, the mills operate via PWM and display :
  • 120 mm:
    • Speed range : 500 RPM to 2000 RPM
    • Air flow : 56,3 CFM
  • 140 mm :
    • Speed range : 600 RPM to 1800 RPM
    • Airflow: 84.3 CFM
Unfortunately, we don’t know the static pressure.
Finally, the pricing is rather affordable since the brand announces a price of 13.50 € for the SC12 and 13.95 € for the SC14.
