In addition to its Eisblock for AMD RX 7900 Series , Alphacool launches Core blocks for NVIDIA cards. These blocks concern the RTX 4090 Founders Edition as well as the models using a so-called “reference” PCB.
Core:Alphacool ‘s waterblocks for RTX 4090!
Of course, we find an ultra-compact block, in accordance with the size of the printed circuit of the RTX 4090 Founders and reference. The waterblock will cover the entire card and will cool its most critical elements: GPU, memory and power stage.
As you can see, the choice of materials is chromed copper and acrylic for the top plate. This model also comes with a nice backplate in black anodized aluminum. Also, we won’t fail to mention the G1/4″ threads in chromed brass!
This model is compatible with a number of cards. So we find the 4090 references, but also the models that use its PCB. This includes the Inno3D X3 OC, iChill x3/Frostbite/black versions. At PNY, we have the XLR8 Gaming Verto OC and non-OC models. Finally, KFA² is also concerned with the SG model (1-Click OC), not to mention the Founders Edition version from NVIDIA itself.
The prices are 199,98 €!
This way to the Alphacool datasheet!
