AH T200: Thermaltake’s case comes in green and turquoise!
The AH T200 case from Thermaltake comes in two new colors: turquoise and racing green. The brand follows the movement started with the Toughfan 12, the Tower 100 and the Toughram which is to put color in their products. This allows the brand to offer more original references than the classic black and white.
AH T200: green and turquoise on the program!
Thermaltake AH T200
As a reminder, this case is a big beast with a helicopter look. Indeed, this model has dimensions of 282 (W) x 551.5 (D) x 444.2 (H) mm for a weight of about ten kg. This is really imposing, especially when you know that only µATX and mini-ITX motherboards can be installed.
Otherwise, the storage part remains rather classic with the support of two 3.5″ units. For the 2.5″ storage, we find three slots.
Regarding the rest of the components, Thermaltake puts forward :
  • 320 mm for the graphics card
  • 150 mm for the CPU cooling unit
  • 180 mm for the power supply
In terms of cooling, it will be possible to install up to four fans in 120/140 mm. Of course, three-fan watercooling radiators are not compatible. We will therefore be satisfied with models in 280/240 mm maximum.
In short, with this case, the brand plays the card of originality. Here, with these green and turquoise versions, we have five different colors if we count the pink, black and white. For the price, it’s hard to say, but it seems that the paint doesn’t make the bill go up. As a reminder, the pink model is priced at $169.99, so we can expect the same pricing for these variations.
Here and here are Thermaltake’s datasheets !
