AG400 Digital: DeepCool’s entry-level fans also with display
DeepCool announces its AG400 Digital fans. As a reminder, the AG series offers an entry-level alternative to the AK models. Here we find affordable heatsinks with a digital display!
AG400 Digital: entry-level with temperature monitoring!
DeepCool AG400 Digital
The program includes two configurations, one basic, with a single fan. The second, called “Plus”, features two push/pull fans for greater performance… But also more noise.
Other than that, these heatsinks are based on the brand’s AG series, but the visual aspect has been given special attention. The fins are coated in black, with the first fin featuring numerous grey squares. As for the digital display, it is housed in the “holes” in the fins of the original series. Unfortunately, there’s no customization here, and it will only display the CPU temperature.
As with the 400 model, this is a classic configuration based on four copper heat pipes. These come into direct contact with the processor, while the base is slightly eccentric for better RAM compatibility.
Ventilation is provided by two RGB fans operating from 500 to 2100 rpm. At maximum speed, airflow reaches 75.89 CFM, while static pressure rises to 2.53 mmAq.
Prices have also been announced. Expect to pay €38.99 for the AG400 Digital, versus €44.99 for the Plus version.
