Temperatures
Processor at 65W
Despite a more violent 65W profile, the latter still represents the least stressful phase of this protocol. It allows to highlight the performances obtained with compact/entry-level heatsinks. These results are only indicative for the largest heatsinks (AIO, large dual tower, etc.).
We continue our tests with the temperature readings on our 65W power profile. At this level, the T120 RGB from NZXT is at the level of the heatsinks sharing more or less the same configuration: four heatpipes. On the other hand, we feel that the Freezer 34 from Artic is more comfortable on high speeds, ditto for the Pure Rock 2.
Processor at 95W :
Here, our CPU will run at 3.90 GHz constantly and on all its cores. We apply a VCore of 1.375V to obtain a consumption of 95W approximately. To simplify the reading of the graph, we may have rounded some values to the nearest integer.
In 95W, we find a heatsink rivaling the Freezer 34 signed Arctic at low rpm. On the other hand, the NZXT fridge has a temperature increase at higher speeds. On the other hand, it is interesting to see it compete with the Dark Rock Slim on all its speeds!
Processor at 125W :
Finally, we finish with our 125W profile. Here the heat release is more important, let’s see how our coolings do !
In 125W, unfortunately, this T120 RGB does not manage to contain the heat generated by our Ryzen 7 1700X. So it fails in this case.
Otherwise, it lags seriously behind the Freezer 34 of Arctic, especially at low speeds, while continuing to dominate the Dark Rock Slim of be quiet!
Summary
The T120 RGB from NZXT logically offers temperatures in line with its size. This model with four heatpipes in direct contact with the CPU competes with Hyper 212 Evo, Dark Rock Slim and Freezer 34. Nevertheless, if it is rather good at low rpm, it will lag slightly behind the competition on its higher speeds. Let’s see what it will give you in terms of temperature/noise ratio.
![[Tweak League] Tutorial: Overclock your RTX 4060 and get 10% FPS](https://en.overclocking.com/wp-content/medias/sites/4/2024/07/overclocking-gpu-rtx-4060-occ-scaled-218x150.jpg)
