Protocol
We’ll only be showing you the readings taken on our Ryzen 7 7900X consuming 105W and 170W. No 65W, as we don’t think this consumption is relevant for assessing the performance of AIO kits.
Here, we are now measuring the delta between the temperature measured on our CPU and the ambient temperature. Finally, the management of the fan speed is now entrusted to our motherboard. During the tests, we run the fans successively at 100%, 66% and 33%.
For the purposes of the test, we will compare the Navis F360 aRGB with other models in 240, 360 and even 420 mm:
- iCUE Link H170i RGB (Corsair)
- iCUE Link Titan 360 RX RGB (Corsair)
- Kraken Elite 360 RGB (NZXT)
- Light Loop 240 (be quiet!)
- Liquid Freezer II 240 (Arctic)
- MAG CoreLiquid i360 (MSI)
- ML240 Atmos (Cooler Master)
- Navis F360 aRGB (Endorfy
- Ryuo III 360 (ASUS)
