Overclocking.com video
Protocol
Small update of our test protocol. Indeed, we changed the software we were using to stress our configuration. The same goes for the different profiles. By the way, you will see that our configuration has recently received a new power supply. It is a RM750x from Corsair. Of course, we will always focus on temperature and noise measurements.
The wiring of the fans is not supported by our rehobus, so we set the ventilation manually via the bios of our motherboard. They will operate respectively with a PWM signal of 30%, 50% and 100%.
![[Tweak League] Tutorial: Overclock your RTX 4060 and get 10% FPS](https://en.overclocking.com/wp-content/medias/sites/4/2024/07/overclocking-gpu-rtx-4060-occ-scaled-218x150.jpg)
