Review : Alphacool Eiswolf 2 AIO – 360 mm RTX 4090 TUF
The final word:
It’s time to give you our impressions of the Alphacool Eiswolf 2 AIO – 360 mm RTX 4090 TUF cooling system. With its AIO, Alphacool offers an excellent all-round cooling solution, meaning that no additional components are required. The other strong point of this system is that it is upgradeable. You can later add an additional radiator or a system to keep your processor cool, for example.
The price of 270 euros seems totally coherent to us for all the components of this kit, i.e. the waterblock, the pump and the 360 mm radiator. The finish of the components is very good, with only a few elements, such as the end caps, showing paint chips, probably due to tightening during installation. This is a single-use waterblock dedicated to the UFC, but this will also be the case if you only buy a waterblock for your graphics card. So, if you change graphics cards in the next few years, you’ll have to think about reselling it with the Alphacool system to recoup your investment.
Performance is good, but a little lower than usual, thanks to the RTX 4090 TUF’s excellent cooling system. If you already have your own cooling loop, you can choose a waterblock from the new “Core” series, which will be tested and online tomorrow.
RELATED STORY
Review - Endorfy Liv and Liv Plus Onyx White Wireless
The Alphacool Eiswolf 2 AIO – 360 mm RTX 4090 Strix/TUF kit:
We liked:
  • Full-color installation instructions in three languages! (EN – DE – FR)
  • High-quality packaging and bundle
  • Turnkey system for beginners
  • Easy installation for everyone
  • Kit upgradability thanks to quick connectors
  • Pre-cut thermal pads
  • Alphacool’s approach: a system halfway between classic AIO and custom watercooling
  • The quality and rendering of aRGB backlighting for the waterblock
  • Waterblock design quality
  • The compact format of the RTX 4090 with this cooling kit
We would have liked :
  • Plastic washers instead of foam washers
  • A better finish on some parts with paint chips (pump tips)
  • Better quality thermal pads in case of disassembly
médaille award OMF or goldAlphacool’s 360 mm Eiswolf 2 AIO kit is an excellent cooling solution. Its ease of installation, even for a beginner entering the world of watercooling for the first time , combined with its upgrade potential to expand your cooling loop, are non-negligible assets. The use of a waterblock also allows your RTX 4090 to return to a more compact format. Many thanks to Alphacool France for providing this Eiswolf 2 AIO – 360 mm RTX 4090 Strix/TUF kit.
